"ADD TONER" Light will not go away,Canon IR3235
  • Atrat
    • Oct 2014
    • 18
    The copier ran out of toner and there was none on site. So they kept shutting it off and on, to make copies. I installed the new toner bottle and manually added toner thru the service program,because it wouldn't do it automatically. Toner / Install. Then it says OK. It runs for a while and comes back saying "add toner". What am I missing? Thanks.
  • roho
    • Mar 2009
    • 844
    Re: "ADD TONER" Light will not go away,Canon IR3235
    likely a issue with the hopper assembly. I've had a couple of them go in the past.
    • Atrat
      • Oct 2014
      • 18
      Thank's I'll replace it.
      • Nutstar
        • Mar 2011
        • 110
        it might just need cleaning out and resat. sounds like the DENS sensor isn't reading correctly, that or the hopper unit as a whole has failed.
          • 8132
          When it says add toner cheat the toner door & check that the bottle turns, if it doesn't pull the bottle towards you while its trying to drive, seen this a few times
          • kuby
            • Oct 2007
            • 1395
            Did you run the add toner again the light went out. Sometimes you need to run it again, and run the d-gamma adjustment twice. I know this is for when installing a new drum but if they ran it completely bone dry you need to run this.
            • Atrat
              • Oct 2014
              • 18
              I'll try it and let you know how I make out.Thank's
              • Atrat
                • Oct 2014
                • 18
                I'll give it a try and let you know how I made out.Thank's
                • Atrat
                  • Oct 2014
                  • 18
                  I'll give it a try and let you know how I made out. Thank's
                  • Brian8506
                    • 1664
                    I've had this several times and had to replace the hopper
