iP C 800 : Problems with the (12 inch x 19 inch) from each drawer.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    It ' certainly a setup problem.
    But when I put in the drawer the sheet size 12 x 19, the machine displays the drawer empty .
    This is valid for all drawers and only for that size.
    With the rest of the formats It's all right !
    Where is the setting for to change this ?
  • teckat
    • 16083
    Re: iP C 800 : Problems with the (12 inch x 19 inch) from each drawer.
    U mean 12x18 _?
    or 13x19_?
    or 12x19_?
    In service mode_go to>
    COPIER>OPTION>FNC-SW>MODEL-SZ and set to "1"
    Options for 12x18, 12.60x17.72 and 13x19 will be displayed to select.
    ***For your paper size register it under Irreg Size for 12x19.
    Then under Common Settings , also register the size.
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Originally posted by teckat
      U mean 12x18 _?
      or 13x19_?
      or 12x19_?
      I found the solution: under the Common Settings there's setup for all size for all drawers !
      • teckat
        • 16083
        it's usually right under our noses
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          [ATTACH=CONFIG]27422[/ATTACH]
          Yes !
          But haste prevents us from seeing it!
