Canon IR 4570 Copying Speed.
  • JeyJey
    • Dec 2014
    • 5
    [Misc] Canon IR 4570 Copying Speed.
    Hello Folks.
    It's seems that when i place paper (letter) horizontally LTRR the copying speed reduces to about 22 ppm, but when it's placed vertically LTR in the drawer, the speeds seems normal, about 40-44 ppm.
    Is this the way this machine function or there is a setting i'm missing?
    Thanks.
    • 23007
    Re: Canon IR 4570 Copying Speed.
    The ADF/print speed is always based on A4/LTR not A4R/LTR-R. There are other factors that can slow it down though. Perhaps the fax is to set to Fine resolution, or perhaps Mixed Originals has been defaulted. But in the end it will always take longer for 11" of paper to pass than 8 1/2". =^..^=
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      Its absolutely normal, and have you checked that if you run 11x17 (Ledger size) paper is much slower?, this is because -logically-the longitude of the paper passing through the machine takes a longer time. A Letter-R paper has a longitude almost double than a LTR (positioned) paper.
      This is normal and happens in all machines of all brands.
      (see the specifiations brochure closely and you'll see).
      By the way are you a tech? this is basic knowledge.
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
      • teckat
        • 16083
        DADF-N1
        A4 22ipm (iR 3570), 28ipm (iR 4570) A4 45ipm at 300/600dpi 565 x 538 x 122mm Approx. 8.5kg
        Scanning Speed: 28 Images per Minute (ipm) (Letter @600 dpi), 45 ipm (Letter @ 300 dpi)
        • JeyJey
          • Dec 2014
          • 5
          Originally posted by teckat
          DADF-N1
          Thank you.
          • JeyJey
            • Dec 2014
            • 5
            Thank you man.
