IR 5000 to make it connected
  • gautammehta
    • Aug 2025
    Hi,
    I have IR 5000. which is said as non connected machine.
    I want to know which all parts do I need to make it connected?
    DO I need Boot ROM?
    DO I need Ethernet Card?
    DO I need RIP board?
    Gautam
  • 555
    • Jun 2008
    • 45
    you need to install a network boot rom and a n.i.c., then you need to reflash machine with network system software. while your in download mode you may as well update nboot,language, and rui.
    • vandezo
      I don't know
      • 161
      in ir5000d..........
      * you mean connected with LAN : yes, you need a ethernet card. & it make your scangear on.(scanner).
      * you mean connected with printer LPT1 : you need to replace your BOOTROM with N series, & make your update system on harddisk. (not ethernet card required)
      ir5000 s
      * you mean Connected with printer : you need a RIP BOARD (not BootRom Change required), then you must update your Hardisk system.
      • gautammehta
        Thanks for your reply.
        If I Just want to print via Network/LAN on IR 5000s than do I still need print board? or having Ethernet card is enough?
        Is this also means, if I want to print on any IR5000 model via LAN I do not need print board ? or is there any series of IR 5000 which have to have print board in order to make it print ?
        Gautam Mehta
