Canon irc2620
  • stobby2
    • Oct 2013
    • 137
    Canon irc2620
    We have a customer with IRC2620. Copies are perfect for small runs however if they do long run of say 30 or more copies image begins to have a slight red tint appearing, gradually gets worse. Was at machine yesterday and ran 20 copies no problem, after that they ran 50 and problem still persisted. Any Ideas.
    UK Rog
  • copier tech
    • 8193
    Re: Canon irc2620
    Sounds like the magenta drum needs replacing, what % life does it show?
    • stobby2
      • Oct 2013
      • 137
      Re: Canon irc2620
      Thanks for that. Stupidly l did not get the drum count when l was there yesterday. Senior moment!! (our canon guy is on vacation l usually maintain the Ricoh machines) l reckon you are probably correct. Will go back today, get the count and if low will order a magenta in. I assume if it is low it is scraping the remaining (CRAP) out of the unit.
      Thanks again
      Rog
      • teckat
        • 16083
        Re: Canon irc2620
        UK Rog
        do u see background covering a PG6 GRID TEST PRINT from service mode ??????
        how old are Drums ?? especially MAGENTA
        u mean background is covered ?
        Background is on Copies and Prints.
        last time customer ran a full calibration ?
        Check the four bias tabs on the Drum Unit Cover. The bias tab may be pushed in and stuck. If the tab is stuck in, it will create a poor contact to the bias tab on the drum unit resulting in background on the copies. There is one tab for each drum.
        Below is a picture with an arrow pointing to the bias tab.
        • stobby2
          • Oct 2013
          • 137
          Re: Canon irc2620
          I have been back today and checked magenta drum unit which is low. i have ordered a new unit however l will pop back tomorrow and re-check the bias tabs. The magenta background is over the copies but quite light. Appreciate you getting back to me. Much appreciated.
          With your suggestions and a new unit l am sure we can sort the problem
          Thanks again Guys
          UK Rog
