Scan to file with SMB
  • Rachid.Akli
    • Oct 2011
    • 595
    [Misc] Scan to file with SMB
    Hi to all and Merry Christmas.
    We have a customer using Kaspersky antivirus and we are trying to configure the SMB scan to file option (IRAC2220i). The antivirus is blocking the communication. I am looking for a solution if someone can help.
    Thanks in advance.
    Rachid.
    "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
    • 16083
    Re: Scan to file with SMB
    Try disabling Anti-Hacker blocking rules for SMB protocol:
    Open Kaspersky Anti-Virus and click Settings.
    Select Anti-Hacker in the left frame and click Settings in the Firewall section.
    Disable the following options in the Rules for packet filtering tab:
    Windows "Server Message Block" Activity TCP.
    Windows "Server Message Block" Activity UDP.
    Click OK.
    Sometimes useful to disable TCP/IPv6 in network connection properties.
    Kapersky Anti-Virus:
    - Trusted Network: Networks in Kapersky can be setup as Public, Local or Trusted. For SMB sharing to be allowed by Kaspersky, the network has to be either Local or Trusted.
    - Blocking of Local UDP & TCP:
    The Firewall setting in Kapersky may choose to set the Packet Rules for local UDP and TCP permission to "Block" by default. Set these two permissions to "Allow" .
    - SMB Blocking by Anti-Hacker:
    Kapersky's Anti-Hacker program from earlier versions of Kapersky, can check off SMB sharing as potenital threats by default.
    - Windows 8 Modifications:
    Kapersky may modify Windows 8 from the default state that your Windows 8 Sharing PDF would have setup your computer.
