can ir6570 print using tracing paper?
+ More Options
Posts
  • 813200217
    • Oct 2014
    • 51
    can ir6570 print using tracing paper.???
    i never tried that before???
  • Ctl-Alt-Del
    • Jul 2006
    • 430
    Re: can ir6570 print using tracing paper?
    Maybe, what are the specs on the paper?
    • teckat
      • 16083
      Transparency
      BT-400 Trasparency
      4mil/142gsm
      tracing paper sizes---
      A3, B4, A4R,
      A4, B5R, B5
      use in manual feeder tray only
      Some types of tracing paper cannot be used-
      Feed tracing paper one sheet at a time, and remove each sheet as it is delivered to the output tray. Loading several sheets of tracing paper together may cause paper jams.
      If you select [Transparency], [Tracing Paper], or [Labels], make sure that you do not specify any Finisher modes (Collate, Group, or Staple).
      • 813200217
        • Oct 2014
        • 51
        i already tried, ir 6570 can print using tracing paper..
        but there is another problem..
        i have 2 ir6570 and 1 ir5075..
        three of them have the same problem
        i insert the tracing paper to a3 drawer.. then i print it.
        it always has a cease side..
        any suggestion?...
        anyway, i already refuse that order (print using tracing paper)
        • teckat
          • 16083
          any suggestion?...
          sorry about that note on Transparencymy mistake----
          [QUOTE][/can ir6570 print using tracing paper.???
          QUOTE]
          If you are making prints on Tracing Paper, labels, transparencies, or nonstandard paper size stock, load the paper stock into the stack bypass.
          *****use in manual feeder tray only(stack bypass)one sheet at a time
