IRC 3200 - Drum life??? Number?
  • Adrian_Boy
    • Dec 2014
    • 19
    Hi,
    This is my first post :P
    I have a IRC 3200 printer machines and i dont know what is means this number, the drum life number is between 1 and .... ???
  • copier tech
    • 8187
    Re: IRC 3200 - Drum life??? Number?
    The drum print quality life is expected to deteriorate at 100% they do however continue to produce good print quality until about 200-250, the black drum will start to leak at around 150% so I would look at replacing yours soon & your magenta has a very high reading.
    If you press TEST then type 10 into the top box PG, the press the start button this will produce a test pattern from this you can check each drum quality.
    • Adrian_Boy
      • Dec 2014
      • 19
      I understood now, numbers displayed are percent about life of the opc drum.
      The opc drum is not so shiny
      I try to replace the opc drum + chip from china site, is this a good method?
      • Nutstar
        • Mar 2011
        • 110
        I would personally not use non genuine parts in these machines, these machines are a pain in the backside at the best of times never mind the worst, you don't need to help them along
        • copier tech
          • 8187
          Worth a try if you are on a budget, but you might get E020 errors as the developer is old
          • Adrian_Boy
            • Dec 2014
            • 19
            I undersdand, but why are made this opc drum (china) if it not good?
            I dont have USD400 to buy genuine, is to much for me, do you have any solutios to low budget?
            Thanks for all!
            • Nutstar
              • Mar 2011
              • 110
              Thanks for all!
              The cheap parts options are, in every sense of the word, a false economy.
              they may be cheaper but 9/10 times you will replace them more often at fewer intervals which means your spending more time, and time = money.
              the cost of parts should be offset by your cost per copy count or your service contract or the customer should be paying for the parts. in any circumstance, if you don't use genuine, you will have problems.
              we only use genuine parts and toners in our machines, there really is no better alternative.
              • Adrian_Boy
                • Dec 2014
                • 19
                Hi,
                I have some questions and i think is not good for each question to creat a new topic.
                In this moment my IRC 3200 is not working, beacause of my fuser, i am waiting a new pressure rolls.
                1. At this time, i dont know what is quality of this machine (in conditions when all the pieces are very good), at the last job i worked on the docucolor 250 - there is a big difference in final print???
                2. It this possibile to print offset paper at 350gsm ?
                I want to know because the parts is not too cheap
                (sorry for me english)
                Best regards,
                • ps22sp
                  • Aug 2014
                  • 83
                  Hi,
                  Best regards,
                  what do you means 350gsm ? card stock
                  over 100 lb cover stock ,running 1000 copies your fuser will die , it will cost you 500 to replace a new fuser (bottom pressure roller)
                  • Adrian_Boy
                    • Dec 2014
                    • 19
                    Hi,
                    In the most cases, the manufacturer does not recommend heavy paper - about 250gsm or maxim 300gsm, but are many users who use a heavyweight paper, what to think, for every 1000 prints all will change the fuser???
                    I want to print Business Cards and i need to print on heavyweight paper.
                    Thanks for my remove fog
                    • Canuck
                      Tech Specialist
                      • 1713
                      Hi,
                      Best regards,
                      1. There are cleaning brushes and seals inside the drum unit, which also holds the developer assembly. It is a waste of time and money rebuilding these units.
                      2. Don't compare this machine to a Doc250. Maximum paper weight is about 253 g/m2(about 10.5 caliper roughly...11 point stock).
                      3. This is a "business,presentation style" color machine, not print for pay. Yes the 250 will feed plywood. This won't.
                      • teckat
                        • 16083
                        Hi,
                        iR3200 Paper Source
                        Paper Drawer
                        (17 lb bond to 110 lb index (64 to 209 g/m2))
                        Stack Bypass
                        (17 lb bond to 140 lb index (64 to 253 g/m2))
                        Paper Deck
                        (optional) (17 to 110 lb index (64 to 209 g/m2)
                        Heavy 1 *3 = use in all locations
                        *3= Heavy 1 paper is from 28 lb bond to 110 lb index (106 to 209 g/m2).
                        Heavy 2=*4= bypass & deck only
                        *4= Heavy 2 paper is from 80 lb cover to 140 lb index (210 to 253 g/m2).
                        Recycled *2 = use in all locations
                        *2 = Recycled paper is from 17 to 20 lb bond (64 to 80 g/m2).
                        Tracing Paper *5 = bypass only>one sheet at a time
                        Glossy Paper
                        *6 = bypass only
                        *6 = Glossy paper is from 60 to 110 lb index (157 to 209 g/m2).
                        Transparency *7 = draw & bypass only
                        *7 Use only LTR transparencies made especially for this machine
                        • Adrian_Boy
                          • Dec 2014
                          • 19
                          Thanks for all
                          In this situation, Who is the guilty?
                          - PCR roller
                          - OPC drum
                          Lines are from...???CCF25012015_00000.jpgCCF25012015_00003.jpgCCF25012015_00001.jpgCCF25012015_00002.jpg
                          Please help!
                          • copier tech
                            • 8187
                            The drum cylinders are worn, that's why you have these lines & poor quality solids.
                            • Adrian_Boy
                              • Dec 2014
                              • 19
                              Thanks, but the PCR roller are not responsible for this?
