Canon IR ADV C2220L
  • adminguru
    • Sep 2025
    [Misc] Canon IR ADV C2220L
    Hello,
    I have two problems with my printer:
    1- the printing is pad : the top of the page is good but from the middle start loosing the print and no printing at the bottom.
    I tried to clean the laser unit, changing the drum but the problem is persistent.
    2- some times the printer indicate a jam and when I open it there is no paper jam !! a pick-up or feeder problem I think.
    please provide a solution with pictures or video.
    thanks.
  • vamoursly
    • Sep 2011
    • 273
    Re: Canon IR ADV C2220L
    Problem 1 - did you clean the laser mirrors by opening the shutter / take a look at the secondary transfer roller
    Problem 2 - which Tray does it Jam from, If its Tray 1 you need to change the pickup roller, its a completely different type from the other tray
    Dead easy to do, you got a service manual?
    V
    • adminguru
      1 - can you provide photo or video on how to clean the shutter mirror please (I don't have service manual for the printer do you have one?)
      2 - yes the 1st tray is the jam source because the 2nd one print normally sow how to get the roller pick-up changed ?
      thanks.
      • Ozon
        • 6
        imagerunner_advanceseries.pdf
