Imagepress C6000 Reverse/Outside Delivery open
  • tpant
    • Apr 2014
    • 67
    [Misc] Imagepress C6000 Reverse/Outside Delivery open
    The reverse / outside delivery unit show unlocked but it is locked. Inspected and tested with know good sensor no change. Been also having random e261 errors.
    • 16083
    Re: Imagepress C6000 Reverse/Outside Delivery open
    check connection
    e261-xxxx
    xxxx=what is all important sub code
    • tpant
      • Apr 2014
      • 67
      It is e260-0102. I have changed with good fuser driver boards and also tried swapping the whole fuser. The e260 went away randomly for no good reason. I am now left with the warning the the reverser is not locked. Try to figure what would be a common pcb or connection. It seems to be a bad connection etc.
        • 16083
        U first said E261_?
        Now it's E260-0102_?
        Are u sure about CODE_?
        E260 error code indicates a loss of 24 vdc, 12 vdc, 13 vdc or 5 vdc
        Manual points u for checking areas.
        • tpant
          • Apr 2014
          • 67
          Sorry. Seen so many were things on this I am lossing track. It is e261-0102. As per the manual I have changed everything except dc-con 1-2. That has now disappearwd and the door/lever open warning s the problem.
          • tpant
            • Apr 2014
            • 67
            This is the current problem. The lever complains open even though it is closed.
            • tpant
              • Apr 2014
              • 67
              If I unlock say the fixer it show that as open, close fixer shows closed. Any lever on the reverser I open/close doesn't show any change.
                • 16083
                The display shows the Reversal Assembly Lever is disengaged.
                Check COPIER>I/O MODE>DCON>P031 bits 5 and 6 (1 = connected to DCON and 0 = not connected to DCON).
                Bit 5: Detection of connection of the Color sensor control PCB 1 UN308 Front
                Bit 6: Detection of connection of the Color sensor control PCB 2 UN309 Rear
                If one or both bits are 0 the Color sensor control PCB and/or DC Controller PCB 1-2 may be defective.
                A connection or wire harness failure is also possible; check connections from DC Controller PCB 1-2 J1076 side A and B to the Color sensor control PCB J3502F (front) and J3502R (rear).
                Does the Reversal Assembly Lever Switch (PS381) check good at J4033 on the Duplex Feed Driver PCB.
                Check or replace the Draw Assembly/wire harness (FM2-9287-000)
                  • 16083
                  "Check that indicated guides or levers are in the correct position" message.
                  After securing all of the levers in the Reverse Delivery Assembly, re-seat the connectors to the Pre Fixing Feeder Driver P.C.B.
                  NOTE ** You may have to do this multiple times.
                  • tpant
                    • Apr 2014
                    • 67
                    You nailed it. Reseating those connectors seems to have solved the problem. Thanks.
                      • 16083
