C5045 No Black & Loud Noise
  • mrfuser
    • 1603
    Client has an imagerunner advanced C5045 that over the weekend started making a loud noise from rear of machine and making blank pages on black. Is this a dead black laser unit?
    Thanks all!
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: C5045 No Black & Loud Noise
    Hello,
    Either the dev unit or the drum cylinder is not turning.
    Rachid
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • canon33
      • Jun 2014
      • 65
      My guess is that the main drive assy needs replaced. There is a nylon bushing in that assy that gets hosed.
      • Canuck
        Tech Specialist
        • 1713
        Check the little plastic "prop" on the rear of the dev...the one that drives the dev cylinder. They strip inside. Actually there is a mod for this......
        • canon33
          • Jun 2014
          • 65
          That doesn't cause a loud noise at rear of machine that OP mentioned.
          • mrfuser
            • 1603
            I toured apart drum and developer look of look fine I don't see any strip gears. In service mode I can print out yellow blue and magenta just no black. The loud sound comes from what looks like a motor down below the drum units, is this possibly a laser drive?
            • Canuck
              Tech Specialist
              • 1713
              I have had the coupling at the rear break a piece off. It is spring loaded and yes, it makes a noise. More of a soft thumping. Just supplying some info. Thought it included this in it....this one makes noise
              • canon33
                • Jun 2014
                • 65
                Ck main drive assy. Is the coupler on the drive assy that locks into the developer assy? Kinda hard to see bit if u remove drum tray u can look back there. Also reach back there and turn by hand each of the couplers and u will probably feel a difference in the black drive coupler. U need to replace main drive assy.
                • mrfuser
                  • 1603
                  Do you have a part number for that drive assembly?
                  • Canuck
                    Tech Specialist
                    • 1713
                    FM4-8390...just transfer the motors from the old one. Read the last bulletin I posted
                    • mrfuser
                      • 1603
                      Can I swap anything so they can use black in the mean time?
                      • Canuck
                        Tech Specialist
                        • 1713
                        Swap the bushing on the black with one of the other colors to keep it going...or see my PM
                        • mrfuser
                          • 1603
                          Any way to order the bushing alone? Sure enough this one is trashed!
