Canon IR3030 Z Fold.
  • netbaba2000
    • Jul 2014
    • 21
    Hi Friend.
    I have canon ir3030 Printer.
    some pages copy out with ( Z ) fold same in tray-1 ( A4 ) and tray-2 ( A4R ).
    thx
    • 23009
    Re: Canon IR3030 Z Fold.
    What have you done so far? What jam codes? =^..^=
    • allan
      RTFM!!
      • 5462
      How is the image registration on the ones with the folds? Is the area in the folds void or not?
      Whatever
      • netbaba2000
        • Jul 2014
        • 21
        Hi.
        No Jam Code shown in service panel. and pint is overlap on top-of fold side.
        middle of paper is blank.
        thx
        • allan
          RTFM!!
          • 5462
          Check the registration section clutch and sensor including transport clutch and sensor before that. The transport drive does not stop even after loop creation. sounds like a bad clutch or a sticky sensor.
          Whatever
          • netbaba2000
            • Jul 2014
            • 21
            Hi
            Thanks for reply.
            can u give me part number of registration section clutch,transport clutch & sensor.
            Thx
            • allan
              RTFM!!
              • 5462
              Don't just replace all of it find the problem a lot of the time it is something real small and can be corrected. like a dirty or sticky sensor or actuator.
              Whatever
              • netbaba2000
                • Jul 2014
                • 21
                oke thanks
                trying my best to find this problem.
                • allan
                  RTFM!!
                  • 5462
                  Originally posted by netbaba2000
                  oke thanks
                  Hope someone can help you from the Canon forum for parts. The advice i gave you was to figure out if the fold is created before or after registration. If the space in the fold was not void then you check if the toner is fused, if the toner is fused it means the fold is created after fusing. But normally a nice fold i created by a long solid roller.
                  Whatever
                  • sureshraidu
                    • Oct 2011
                    • 28
                    I think you have given extra pressure at the lower right cover using double sided tape or a screw,
                    if still u have problem, u can call me 09766143007.
                    • netbaba2000
                      • Jul 2014
                      • 21
                      Hi allan
                      I checked all registration section all fine. gear is ok, sensor is clear working file but some time z fold appear.
                      on zfold printing is clear.
                      what is long solid roller ? is this a part of fuser assembly ?
                      thx
