Dead Printer board on a IR400
  • copyj8
    Hello all,
    I have an IR 400 that no longer sees the printer board. I have checked all of the connections on the PDL interface board and the printer board. I have also tried replacing the hard drive. Any help would be appreciated. I am spending more on inkjet cartridges than gas!
  • Oze
    Ricoh Fanboy
    • 1663
    I had an iR400 that the printer board died in just 2 weeks ago....solution?
    We sold them a brand new machine.
    Sadly Canon no longer make that particular board as it also acts as a Rip.
    It's usually not the Printer board that dies but the sub pcb that connects to the board via a ribbon cable.
    Your ONLY chance is to hope like hell you can source another board from a scrap machine.
    • digitalbrain
      have u tried it in another machine ??
      Sometimes tthe pins on the white connector connecting the PDL board to IP board gets bent and give this problem
      • narenkrs
        TECHNICIAN
        • Aug 2008
        • 31
        Originally posted by copyj8
        Hello all,
        An error E677 001 is noted while the printer board is started up.The power-on signal from the printer board does not reach the IP Board (image processor PCB).Chek between ribban cable & connector be carefully.
