Liquid for cleaning
  • V-P
    • Apr 2011
    • 679
    [Misc] Liquid for cleaning
    What kind of liquid are you guys using for cleaning registration rollers ?
    Water - Degreaser ?
    I have been using some kind of de-greaser for cleaning the registration front roller on a irac9060 but the customer is feeding mostly offset paper and I find myself doing frequent cleanings.
  • allan
    RTFM!!
    • 5462
    Re: Liquid for cleaning
    water. paper dust comes of the easiest with a microfibre cloth and plain water. Other places paraffin works well but dont use it on covers.
    Whatever
      • 23009
      For anything rubber I'll use Contractors De-Solv-It orange oil based degreaser.
      Contractors' Solvent - De-Solv-it
      It doesn't dry out rubber parts and does a passable job on plastic covers and matts.
      For inked or dirty plastic covers I like Zep Fast505.
      Fast 505 Cleaner & Degreaser - Details
      It works wonders on ink, toner and generally smudged covers. It's a little too sudzy for rubber rollers, but overall the two are interchangeable.
      • allan
        RTFM!!
        • 5462
        I used to use strong chemical cleaner in the past but my hands got messed up by it. For covers and glass i use windolene. Konica Minolta machines cleans up easily not like ricoh with that whitish covers.
        Whatever
        • vigour
          • Aug 2010
          • 1038
          Are you aware that reg assembly has been modified to prevent static buildup in low humidity environments
          It now has black plastic guide sheet and a varistor
          • teckat
            • 16083
            Martin Yale Rubber Roll Cleaner
            utz Pomade
            :-))__old school
            • V-P
              • Apr 2011
              • 679
              I didn't know - Thanks man !
              One thing it is confusing me though:
              Machine is "OLD TYPE" series.
              Except the guides
              - FL2-8700-000 Upper guide
              - FL2-8701-000 Lower guide
              Do I have to order also the varistor (don't know the part number of it) ?
              • vigour
                • Aug 2010
                • 1038
                They just made the upper and lower available seperately, so I had been ordering the assembly, before that.
                Assembly comes with varistor. So I would just order the assembly
                I have not seen the varistor part no
                • V-P
                  • Apr 2011
                  • 679
                  Do you think there would be any problem if I order new assy on the "old type" machine?
                  Also I see another problem.
                  On the European order page I see only FM3-4758-000 (old type)
                  • vigour
                    • Aug 2010
                    • 1038
                    FM3-4758-020 is the only part no for the assembly. It has been modified twice
                    it is specified for old style and new style.
                    i can't figure out why they have old style and new style upper and lower but one style complete assembly
