IPR C6000 Calibration curve
Re: IPR C6000 Calibration curve
imagePRESS series_ the proper calibration sequence is:
1. Shading Correction. (Visual adjustment or using an I-One calibrator).
2. Auto Gradation (internally or externally).
3 ColorPASS calibration. (Using an I-0ne calibrator or equivalent).
All calibrations should be done on 28lb Hammermill paper.
Color curves fall off sharply at D-Max.
PRINTER only method is good for color adjustment , if the copies still are not looking correct, try the auto gradation from the SCANNER+PRINTER mode for more gradation smoothing.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
I would remove ColorPass Server calibration & redo all calibrations again**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
imagePRESS C7000VP / C6000 / C6000VP
Improving the D Max of the Measurement versus Target Curves
Version 36 DC Con > allows the technician to boost the D Max of an individual color.
In Service Mode Level 2 select COPIER>OPTION>BODY>DMX-OF-X (where X is the color of the curve that drops off at about 95%, Y,M,C or K).
Change the setting from 0 to 1. You must power cycle the machine then run Autogradation and Calibration. Check the curves again. If you need more improvement, you can change the setting to + 2 or +3.
You must power cycle, perform Auto-Gradation and Calibration each time.
OR
When performing Color Cal using the Server, Color Curves fall off sharply at D-Max.
1. Perform a DCON RAM clear
a. Enter Service Mode
b. Navigate to COPIER > FUNCTION > CLEAR
c. Select DCON
d. Press OK
e. Turn the power for the engine OFF/ON
2. Manually re-enter the Specifications stored on the Door Label (do not use a stored back-up)
3. Perform Color Cal again
if the problem persists, a complete Developer change for all four Developer Assemblies may be required.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
