How to turn off SCAN report
  • shrum1340
    • Jun 2008
    • 44
    I have a customer that gets a scan report after every scan. Is there a way to turn this off? I see how to turn off the TX/Rx reports but not the scan.
    thanks
  • teckat
    • 16083
    Re: How to turn off SCAN report
    thanks
    Model
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Turn off the TX/Rx reports!
      • shrum1340
        • Jun 2008
        • 44
        Re: How to turn off SCAN report ir 1025if
        Sorry, ir 1025if
        • shrum1340
          • Jun 2008
          • 44
          Customer wants the fax report after each fax. So if i turn off the TX/RX report wont that eliminate the Fax reports?
          • teckat
            • 16083
            CHECK here>>>>>>>>>>>>>
            press the Additional Functions button and press the Report Settings key. In the left margin, you will see the heading called 'Settings'. Under the Settings header you may have your two options of 'Fax' and 'Send'.
            You can then set the machine to either print or not print a report, or to print a report in the case of an error only.
            all depends on model
            U may have only one Transmission report. It covers both Email and Fax
            check your Printer REPORT SETTINGS in RUI
            see example below
            image from the RUI shows that the TX report does not distinguish between Fax and Email. Please note that the Fax Management report is also outlined in order to clarify that the Fax Management is the Fax Log and not an individual Transmission report.
