C5240i Scanning error
  • fatfingers73
    • Feb 2013
    • 219
    [Error Code] C5240i Scanning error
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: C5240i Scanning error
    -The same error using scan and sand?
    -Controller self diagnosis function?
    • fatfingers73
      • Feb 2013
      • 219
      Thanks for this. Board got delayed at couriers, so will try this when I return.
      Wonder why Canon helpdesk didn't recommend this.
      • zoraldinho
        • Mar 2008
        • 5015
        No problem.
        Also can be bad firmware,bad connector connections....
        • fatfingers73
          • Feb 2013
          • 219
          Morning,
          Managed to fix this by removing re-seating main controller 2.
          Thanks for the advice.
          Hopefully Canon will let me return the board!
          Cheers
          No problem.
          • zoraldinho
            • Mar 2008
            • 5015
            Originally posted by fatfingers73
            Morning,
            Cheers
            Good find!
            I'm afraid you can't return back.
            • fatfingers73
              • Feb 2013
              • 219
              I'm hoping because I have email from their tech team telling me I need the part to clear #859 fault, they will let me return it.
              They have in the past.
              Cheers.
              Good find!
              • onlyinnewfoundland
                • Apr 2013
                • 235
                If you don't cut the tape on the part box, then generally they will take it back.
