Canon Ir3035 Error E0024 - 001 every time you make a legal copy.
Re: Canon Ir3035 Error E0024 - 001 every time you make a legal copy.
Re-seat dev connector from machine where it plugs into dev housing. Make sure connectors are re-seated on both sides of connector(toner senor plugs in on bottom side of connector I believe). Strange its only on that paper. Also clean and apply conductive grease to silver reg roller ground clip...maybe electrical noise
The fault is for a missing connection signal. Crap toner or dev issue would generate E20 errors. Open wire in toner sensor could cause both, but can't see bad toner causing E24
Hi,
I have seen it so many times in this series. It seems to be incoherent, but i have seen it.
Rachid.
"Find a job you love and you’ll never have to work a day in your life." Nagy's father
