Canon Ir3035 Error E0024 - 001 every time you make a legal copy.
  • tibbs
    • Aug 2008
    • 225
    Hello, I have a canon Ir3035 with an error E0024 - 001 every time you make a legal copy or A3 copy.
    Can anyone help with this problem.
  • Canuck
    Tech Specialist
    • 1713
    Re: Canon Ir3035 Error E0024 - 001 every time you make a legal copy.
    Re-seat dev connector from machine where it plugs into dev housing. Make sure connectors are re-seated on both sides of connector(toner senor plugs in on bottom side of connector I believe). Strange its only on that paper. Also clean and apply conductive grease to silver reg roller ground clip...maybe electrical noise
    • tibbs
      • Aug 2008
      • 225
      Thanks I will try that to see.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        If you're not using canon genuine toner, vacuum the developing and the hopper assemblies and instal a genuine toner bottle.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • Canuck
          Tech Specialist
          • 1713
          The fault is for a missing connection signal. Crap toner or dev issue would generate E20 errors. Open wire in toner sensor could cause both, but can't see bad toner causing E24
          • Rachid.Akli
            • Oct 2011
            • 595
            I have seen it so many times in this series. It seems to be incoherent, but i have seen it.
            Rachid.
            • tibbs
              • Aug 2008
              • 225
              I don't understand what connection signal you guys are talking about. Please explain.
              • tibbs
                • Aug 2008
                • 225
                Can you explain what the connection signal is
                • Canuck
                  Tech Specialist
                  • 1713
                  When you remove the developer assembly you have to unplug it....and the code means it lost connection at this connector.
                  • Rachid.Akli
                    • Oct 2011
                    • 595
                    Hello,
                    We fixed some of these isssues by replacing the Devloping toner sensor.
                    Rachid.
