IRC 3200 Color coverage - Papper jam in fuser.
  • Adrian_Boy
    • Dec 2014
    • 19
    [Jamming] IRC 3200 Color coverage - Papper jam in fuser.
    Whay i print or copy with the full color coverage paper jam in fuser unit???
    What is the trick?
    - i print to normal paper 80g
    - when i print less toner, it is ok.
  • SAZ911
    • Mar 2013
    • 193
    Re: IRC 3200 Color coverage - Papper jam in fuser.
    What is the trick?
    [ATTACH=CONFIG]27940[/ATTACH]
    Hi,
    I recommend you replace the fuser unit, the first tell tell signs of a fuser assy wearing out is when it jams on full colour. Had this many times, recommend replacing the fixing assy as well as the pressure roller, as it tends to get flat spots quite often, and will also add to your jamming issues.
    Fixing assy : FB6-3641
    Pressure Roller : FB6-3653
    Hope this helps....
    SAZ911..........
    • Adrian_Boy
      • Dec 2014
      • 19
      Thanks for the answer!
      But, i forgot to mention i change the rollers (NEW up fuser roller and lower roller).
      I see this issue is happen when i use normal paper 80g.
      I have adjust the nip fuser at 3,15mm, but i forgot to up-date in the service mod (*28*).
      I wait suggestions.
      PS > it something wrong with the transfer belt?
      • copier tech
        • 8133
        When you replace the fuser rollers as you know you have to undo the NIP screws & there is no real accurate way to set them back correctly, this is why I always replace the complete fuser.
        All you can do is keep ajusting the NIP untill the machine will successfully feed a pg 10 test print!
        Also you can increase the blank lead edge this helps a lot, I sometimes have set this as high as 150 in order to do full page colour after replacing the fuser rollers.
        • Adrian_Boy
          • Dec 2014
          • 19
          Sorry but, what is mean 150 ?
          • copier tech
            • 8133
            In service mode, COPIER>AJUST>BLANK adjust T
            • Adrian_Boy
              • Dec 2014
              • 19
              This is the setting?
              What values should i try?
              • copier tech
                • 8133
                Yes that is correct, change T, L, R, B all to 150 see if you can print the pg 10 test print, if it does print change the blank settings untill you are happy
                • Adrian_Boy
                  • Dec 2014
                  • 19
                  I ajusted the Blank T at 200 and is the only scale, it doesn`t work lower than that. Any sugestions? Also, i want to ask you if you can help me please with the setting for heavy paper? I want to make the setting for heavy paper but i will use normal one so the printing speed should be slow without rolling up the superior roller.
                  • copier tech
                    • 8133
                    Set all T,B,L,R to 200 can you make a pg 10 test print?
                    • Adrian_Boy
                      • Dec 2014
                      • 19
                      Not, just T, is this a problem?
                      • Adrian_Boy
                        • Dec 2014
                        • 19
                        Hi,
                        Were can i find this part?
                        I don`t find it to alibaba
                        Canon FM3-3775-000 (FG6-9662-000) Swing Plate Gear Assembly
                        • copier tech
                          • 8133
                          Is this the ITB drive gear? I have this item, it is the modified metal one, where are you located?
                          • Adrian_Boy
                            • Dec 2014
                            • 19
                            Thanks, i sent you a PM.
                            I dont know as work?
                            Is have only 400.000 prints.
                            • copier tech
                              • 8133
                              Yes that happens a lot, the new gear is now metal not plastic
