canon ir 3570 cassette 1 sayiing A4
  • sharptech1
    • Oct 2011
    • 163
    have ir 3570 with dial set to ltr but shows up as A4. Is that small board with buttons that cassette pushes or something else?
  • vigour
    • Aug 2010
    • 1038
    Re: canon ir 3570 cassette 1 sayiing A4
    There is a small white switch somewhat indented, in the same dial area, to toggle from metric to imperial
    • sharptech1
      • Oct 2011
      • 163
      correct I can switch between inch an AB with that switch but still shows up as A4 either way. and sm copier>function> model-sz is set to 1
      • vigour
        • Aug 2010
        • 1038
        Sounds like that small board is faulty.
        What happens if you select a different size ?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5009
          I have this issue last week on the same machine.With "dc con clear" A4 come back.
          • copier tech
            • 8143
            Check the tiny black pins on that small board, seen them get snapped off!
            • laitang
              • Nov 2012
              • 627
