Quality issues printing on thick paper
  • V-P
    • Apr 2011
    • 679
    I have a distant customer with a iRAC 5051.
    Customer sent me a scan of his problem.
    The sample was printed using 250 gsm paper.
    Machine has done approx 300.000 copies, so I guess to soon for developers.
    What could be the cause of this? (developers, secondary roller)
    The issue is visible on thick paper. On 80gsm is not visible.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: Quality issues printing on thick paper
    Hi dude!
    There is many bulletins about issues printing on thick paper for ira 50xx and specialy 70xx and ira90xx.Did you tested any of this?
    • SAZ911
      • Mar 2013
      • 193
      Hi,
      Something worth checking.....
      SAZ911..........
      • V-P
        • Apr 2011
        • 679
        Yeah I have seen the pubs - but there is nothing to it.
        On plain paper the image is fine. The problem is on thick paper.
        • onlyinnewfoundland
          • Apr 2013
          • 235
          Is it only in Cyan?
          Get customer to maybe generate some CMYK density sheets in photoshop or something and print them on that paper, see what happens.
          The fusers on these machines leave weird impressions sometimes.
          • V-P
            • Apr 2011
            • 679
            No it happens in all colors. That sample was based on cyan.
            This case is more about expectations from Canon than anything else.
            Sales guy guaranteed to the customer that devs would run for half a mill with no issues.
            Machine has done 300 K. So we are missing 200 K
            Of course we will play the "500 K is for 5% coverage" card and see what happens
            • zoraldinho
              • Mar 2008
              • 5009
              Definitely is pure developer in developer unit.If machine have average printing 10% coverage or higher no way to reach 500K.I have the same problem on ipc 6000
              500K my ass!
              • Nutstar
                • Mar 2011
                • 110
                that sounds like a good way to get a pis**d off customer to me....
                issue looks to be the transfer to me, although did you check they are telling the machine that the paper is in the heavy 2 bracket?
                • imihm
                  • Feb 2014
                  • 77
                  [ATTACH=CONFIG]28018[/ATTACH]
                  Hi there
                  Although Iam not servicing canon but if there are grids on drums clean it before replacing developers.
                  • V-P
                    • Apr 2011
                    • 679
                    It is a distant customer - so I cannot be sure about paper weight but they have been long enough in business so I trust them.
