Ir7095 paper jump need help
  • ugaa
    • Mar 2013
    • 26
    I have IR7095.The machine hase been kept in store for a while. When switched it shows paper jump but there is no signs of paper jump. I tried to clean the drum an changed the cloth.
    Please help.
    • 16083
    Re: Ir7095 paper jump need help
    Please help.
    U mean Jam Paper_?
    • ugaa
      • Mar 2013
      • 26
      Yes
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4999
        Check paper sensors and flags around jam area.
          • 16083
          Yes
          How long was printer out of commission_?
          Was it covered in a dust free area_?
          Jam location_?
          Remove all paper path assemblies >inspect_clean
          ?? Are u a tech_??
          • ugaa
            • Mar 2013
            • 26
            Jam location_?
            ?? Are u a tech_??
            1 year. It's not kept free dust area. I will check it. I am not tech.
            i bought the machine in UK then exported to Somalia. So the machine is in Somalia now.
              • 16083
              dusty area issue & and the ever-present shipping headache for a printer
              u could have a loose connection to a sensor, or a sensor is out of place.
              printer needs to be stripped down>cleaned & inspected then tested/
              was the finisher also shipped ? & if so> installed properly
              • ugaa
                • Mar 2013
                • 26
                Yes the finisher is also shipped.
                I cleaned again although I do not know where the spencer is located. Once cleaned I received a error code E000568-8001 . Can you help?
                • Manxengineer
                  E000568-8001 if I remember rightly is a fault with exit tray on the finisher? check there's nothing blocking the finisher trays, and that they are moving up and down freely
                  • Canuck
                    Tech Specialist
                    • 1713
                    E568-8001 is a transport shift motor error. Call a tech
                    • ugaa
                      • Mar 2013
                      • 26
                      Error has gone and it's back to the same propel. System screen shows The paper has jammed. I sea no paper in the machine.
                        • 16083
                        this is not about paper>
                        get a tech to look in service mode AT JAM HISTORY
                        Stationary jam from power-on
                        L: location of jam
                        CODE: jam code
                        P: source of paper
