IR adv C5051i Color Registration Problem
  • fbkhan3
    • May 2012
    • 421
    [CQ] IR adv C5051i Color Registration Problem
    Dear techs.I have came across this problem today and looking for your help with this issue.
    Color registration is way out as you can see in attachment I took out the ITB and Drum units and they seem in pretty good shape.Auto Adjust Gradation,Correct shading didn't help.
    Machine has 25K color and 11000 BK clicks on it.
    Thanks a ton for your kind support.
    Regard's
  • teckat
    • 16083
    Re: IR adv C5051i Color Registration Problem
    Regard's
    [ATTACH=CONFIG]28154[/ATTACH][ATTACH=CONFIG]28155[/ATTACH]
    Staggered Color Registration visible on PG10 on the imageRUNNER ADVANCE C5000 Series.
    _
    Remove all 4 Drum and Developer Units and carefully reseat them. This may resolve the issue.
    _Did u try performing a REG CLR in service mode level 2_?
    REG CLR in service mode level 2: Copier > Function > Clear > REG-CLR.
    _After the clear, do a auto color mismatch adjustment
    Also_
    Check the Shutter on the Patch Reader and clean the Registration Sensors.
    Make sure the lens that covers the registration sensors is not scratched and causing a misread of the registration patches on the ITB Belt.
    Registration Sensor Units may need to be replaced
    • fbkhan3
      • May 2012
      • 421
      Thank you very much tacket for the help
      i have Re seated the Durm Units and ITB,cleaned the registration sensor and it's not scratched.
      Did
      REG CLR clear in service mode level 2: Copier > Function > Clear > REG-CLR.
      But Auto color mismatch adjustment is ending up with a message(Auto color mismatch adjustment was stopped,Start correction again).
      Printed Out PG 6 and PG 10 and Yellow is visible in Horizontal lines but vertical lines seems fine and i see an issue with only yellow now in PG 6 .
      Pattern. because if i print something Yellow is overlapping on other colors or like Shadow.
      Regard's
      • teckat
        • 16083
        It has been found that if the values under COPIER>ADJUST>IMG-REG are set to 0 color mismatch will fail.
        Enter the values from the front door label.
        Door Pic_link
        https://lh6.ggpht.com/kVwmIznEqhRY4s...RCU9uDDnw=s113
        "Auto Correct Color Mismatch was stopped. Start correction again. If this error continues to occur, contact your service representative."
        :-D
        The issue may be caused by a faulty Patch Shutter operation. The Patch Shutter is operated by SL1 ( Registration Shutter Solenoid ) and a Shutter linkage. Verify that the Shutter linkage and Patch Shutter moves smoothly, and check the operation of SL1.
        To check the Patch Shutter & SL1 operation: Remove the ITB Belt front cover and locate SL1. Actuate the front door switch, enter Service Mode, Function, Part check, <SL=1>, and activate SL-ON.
        See_PIC link_:-))
        ___Correct any binding and/or replace any defective components.
        FM3-8902-000 Patch Read Shutter Drive Ass'y Includes SL1, mount, linkage & spring see FIG. 321
        FM3-5944-010 Registration Patch Sensor Unit No separate part number for the Patch Shutter see FIG. 323
        FC8-4540-000 Protect Shutter
        • fbkhan3
          • May 2012
          • 421
          Tacket Thanks a ton man.
          I have got it working and see this screenshot attached,the shutter wasn't actually linked with Shutter.
          Still no clue how that shutter nob pop out of that housing.
          Bunch of Thanks and Regards'
          • teckat
            • 16083
            • fbkhan3
              • May 2012
              • 421
              Re: IR adv C5051i Color Registration Problem(Noise)
              One more thing i thought i could take it down but failed So i need your advise on this. That horrible Noise coming from upper right side.
              At every start up or end of the copy job sounds like coming from fuser(Tak..Tak...Tak..Tak),i have took out the fuser Lubricated the fuser film(sleeve) and pressure release system Cams but still no luck.
              I'm sure it's isn't from drum or ITB section.
              Regards
              • teckat
                • 16083
                Regards
                C5051 / 5045 / 5035 / 5030
                Popping Noise is Heard from the Right Side of the Copier
                noise is prevalent, when the fixing motor turns on . Turning on motors in Service Mode failed to help diagnose the problem.
                Replace the Fixing Drive Assembly to resolve the issue (FM3-5967-000).
                Measure to Prevent Noise in the Fixing Assembly.pdf
                Cleaning_Procedure.pdf
                Thumping noise in the fixing assembly
                the brake for the cam in the fixing assembly may be slipping.
                Follow the steps below to remove the grease and provide a better grip for the leaf spring to resolve the noise issue.
                On the rear side of the fixing assembly, remove the black plastic cover shown in the photo below.
                Next, remove the silver bracket with the leaf spring shown below.
                Using alcohol, wipe off all of the grease from the tan gear and black cam shown below.
                Then, wipe off all of the grease on the leaf spring using alcohol and rough up the surface of the leaf spring that contacts the tan gear with Scotch Brite.
                Reassemble the fixing assembly.
                • fbkhan3
                  • May 2012
                  • 421
                  Re: IR adv C5051i Color Registration Problem Fixed
                  Done.
                  So far running very smooth and i owe you i don't know how many beers .
                  Thumbs up and very kind regards for help.
                  Thanks a million
                  • teckat
                    • 16083
                    Done.
                    Thanks a million
                    • Canon345
                      This works but there is an updated TP on this Feb 23 for those who want to dig deeper.
                      • teckat
                        • 16083
                        Thanks for the reminder>>>>>>>>>>>>>>>>>>
                        Minimizing E009-0000, E009-0002 and Thumping Noise at the Fixing Assembly.pdf
                        • ranjith@ast
                          • Feb 2015
                          • 5
                          Regard's
                          Please try REG -CLR in level 2 service mode
                          Also check laser unit
                          • tinnyjay
                            • Oct 2009
                            • 666
                            Regard's
                            You have a problem with CYAN as it seems laser its not writing in the right position or you have a problem with ITB registration roller.
                            "Who loves the roses,must also bear thumbs"
                            • jacob234
                              • Jul 2019
                              • 11
                              Dear All my Friend,
                              I have problem with copier Canon IRAdv C5235 where the yellow color is missing when printing and copying the picture contents of yellow. I replaced Y developer and opc drum without replacing chip.. The result is sill blank paper, no yellow printed into the paper.
                              Any one can help me what should I do?
                              _
                              Also_
