IRC 2380i Blurry
  • vamoursly
    • Sep 2011
    • 273
    IRC 2380i Blurry
    Hello
    Interesting issue on a 2380i
    Black copying and printing working fine, single colours look fine.
    But when you either print or scan using colour the text looks blurry.
    I have tested the drums, changed the ITB, ran an MMI clear
    Auto colour mismatch ran, then autograd
    Any ideas were I should be headed next?
    V
  • teckat
    • 16092
    Re: IRC 2380i Blurry
    Originally posted by vamoursly
    Hello
    V
    Did u clean Patch Sensors_?
    Try Performing _in > LEVEL 2> COPIER> FUNCTION> CLEAR> REG, and then do the adjusting quick and full auto gradation for registration.
    • copier tech
      • 8080
      Try the above, also have you recently done a DC con or MNT clear? If so you'll need to re-enter the factory settings
      • vamoursly
        • Sep 2011
        • 273
        Hello
        Yes, I always ensure the patch sensors next to the black drum are clean.
        Not done a DCON clear, wereever I travel and see IRC2380i machines in the UK there are never ever and settings on the front of the lid.
        I will try clearing the REG and doing an auto grad, will come back, thanks for the advice.
        V
