iR3235 DADF-U1 Pick up Failure
  • songela
    • Mar 2008
    • 216
    The main machine works fine except the Feeder. When a paper is placed on the original tray of the Document Feeder is detected as normal. But when the Start button is pressed, the paper is not picked and the jam indicator flashes.The jam code in the service mode is '0094'. Will you please guys offer your assistance?
  • mosey1100
    • Mar 2009
    • 143
    Re: iR3235 DADF-U1 Pick up Failure
    According to service manual the Feeder is detecting paper in the path (SR1,SR2,SR3) just make sure the sensor flags aren't blocked.
    • wassem
      • Aug 2012
      • 159
      if the pickup rollers rotated and can't pick the document ,may the problem be the two pickup cluthes
      • mosey1100
        • Mar 2009
        • 143
        It could be you can take them apart and clean with alcohol or replace them. I have had rusty ones that were new. You could order DADF-U1 Kit - FM3-7085-000 which has the clutches and separation reverse guide assembly also.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 4955
          Remove dust from sensors.
          COPIER > FEEDER > FUNCTION>SENS-INT
          Practice makes perfect
          If you want something done right, you have to do it yourself
