Canon Ir2220i
  • mohammedmmh
    Canon Ir2220i
    I have a canon ir2220i with interface German and I need to change that interface To English please help me
    • 8195
    Re: Canon Ir2220i
    Page 3.29
    • mohammedmmh
      Re: Canon Ir2220i
      thanks for replay but i don't found that option in my printer
      my software when i log in as developer i don't found lang English all i found lang dutch
      • mohammedmmh
        Re: Canon Ir2220i
        i found option but german language only found
          • 16083
          Re: Canon Ir2220i
          Other Language Modules may have been left out ( depends where printer was manufactured or if HDD was changed & only two languages were loaded back )
          If Languages other than German are not listed in panel selection, u need to have someone load _Language & RUI_Firmware for your printer - Language ver must match the Printer Main ver.(MN-CONT)
          About the Language Module (Language)
          A language module is a unit containing the language data needed to indicate messages in the control panel, each module designed for a specific language.
          -Install only those language modules you need, thus saving time spent for downloading.
          You can switch among installed language modules in user mode: common settings> display language.
          At time of shipment, five modules (languages) are installed. The modules will be lost once you format the had disk, requiring you to install them once again to suit the
          needs of the user.
          In Service Mode>>>>>>>>>>>>>Press the key (*), ‘2’ and ‘8’ at the same time, and the (*)key once again.
          To check the version of the modules, make the following selections: COPIER>DISPLAY>VERSION>LANG-XX. Check to make sure that the version of each language module matches the version of the installed system software; otherwise, use the language module built into the system software to start up. The built-in module is not part of the modules
          that may be selected as the display language; for this reason, you will not be able to make use of the language switch unless you have installed modules
          independently of the system software
