Error Code: Imagepress 6010
+ More Options
Posts
  • kytech
    • Aug 2025
    [Error Code] Error Code: Imagepress 6010
    We keep getting the error E000000-0102-05, but it comes and goes. Could this be a
    bad connection somewhere?
  • teckat
    • 16083
    Re: Error Code: Imagepress 6010
    E000-0102 Error Code Intermittent
    in service mode
    COPIER/OPTION/USER/ FX1BC-SW > set to "0".
    -Fixing Belt Drive Assembly check or replace it.
    -Lower Fixing Belt Timing Belt_check the teeth on belt (XF2-1805-280)
    Check on the Primary Fixing Unit > the Lower Belt Drive Assy.
    This is located on the rear of the lower part of the Primary Fixing Unit.
    Check the transmission shaft, bearing and the 19T gear as shown in FIGURE 816 FIRST FIXING ASSEMBLY, LOWER (2/2) items 40 (FU6-0343-000 which is the 19T gear), item 47 (XG9-0286-000 which is the bearings) and item 55 (FC6-0361-000 which is the transmission shaft).
    You want to inspect these components as the bearing possibly could seize on the transmission shaft and strip the 19T gear. If this occurs, then the lower fixing belt will not heat up due to no rotation and hence the E000 0102 error code.
    Did u check if the fixing belt has damaged or the timing belt is broken.
    • kytech
      Thanks. You were correct. Belt was missing some teeth
      • teckat
        • 16083
        keep up the good work !!
        • petros13
          • Mar 2015
          • 11
          in service mode
          Hi do you know how to get into service mode on a canon and Toshiba?
          • teckat
            • 16083
            why
            u will mess things up/
            • petros13
              • Mar 2015
              • 11
              No I will not,I have never worked on any of those, but i have worked on other brand.
              • teckat
                • 16083
                different Canon models have various ways to enter service mode/or modes
                service mode is useless without manuals
                same thought here
                https://www.google.com/#q=toshiba+printers+enter+service+mode
                • petros13
                  • Mar 2015
                  • 11
                  • petros13
                    • Mar 2015
                    • 11
                    The ones I am interested in is the Toshiba DP6550 and Canon image maket F145300
                    • teckat
                      • 16083
                      Model: F145300
                      what is that
                      • petros13
                        • Mar 2015
                        • 11
                        sxp16622
                        • petros13
                          • Mar 2015
                          • 11
                          Image runner
                          • teckat
                            • 16083
                            sxp16622
                            No such product in Canon line.
                            Guess u are not a tech.
