Canon IR3045 Network Scan - Color Document to Black and White Scan - Very Dark
  • agriz
    • Aug 2014
    • 9
    I am using Canon IR3045. I use microsoft office tool and foxit reader to scan the documents. Black and White documents are scanner properly. But when i scan color document, it is very dark.
    I tried to change resolution to 600 DPI. The scan output is very dark. I changed the resolution to 300DPI and i am still getting the darker scanned copy which is not very clear to view.
    Is there any solution to get good scanned copy of color documents?
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon IR3045 Network Scan - Color Document to Black and White Scan - Very Dark
    Maybe try White Level adjustment, SRV MODE - COPIER - FUNCTION - CCD - WTLV1 & WTLV2. Highlight WTLV1 place an A3 sheet on Platen Glass - ok, then highlight WTLV2 then place an A3 sheet in Doc Feeder - ok. Reboot unit & test. Clean Scan & Platen Glass 1st.
    • cscce
      • Jun 2014
      • 156
      I ran into this problem on an IRA c5030. Running the Auto Gradation (Full Adjust) fixed the problem.
      • MFPTech
        • 486
        Try also the Canon Netgear scanning software and see if it makes a difference.
        • bineeshgeorge
          • Jul 2009
          • 107
          Change the colour mode to half tone in net work scangear.
          Sent from my HTC Desire X dual sim using Tapatalk
