need help Canon CLC 3200
  • teckat
    • 16083
    #16
    Re: need help Canon CLC 3200
    Originally posted by disam
    Multi PDL Network Printer Unit-C1 (is Optional) for CLC3200.
    • teckat
      • 16083
      #17
      Originally posted by ahmed96
      Hi
      how will I connect a fiery I have only got a enternet port on the printer?
      thanks
      CLC3200 Brochure.pdf
      do u have a CLC3200 or a iRC3200 ___
      when u don't choose a C1/2 FieryBox_ iRC3200 has a OPTION for a internal Color Network Multi-PDL Printer Kit/(includes a UFR board and Network Boot DIMM)
      don't think-not sure CLC3200 has that option ??
      u need this for CLC3200
      see pdf attachment
      • ahmed96
        • Mar 2015
        • 11
        #18
        see pdf attachment
        [ATTACH=CONFIG]28491[/ATTACH]
        i have only got Ethernet port on the printer.
        • disam
          • Sep 2008
          • 64
          #19
          plese check the frontcover, do you have a irc or a clc
          • teckat
            • 16083
            #20
            what is your location ??
            is printer CLC3200 or iRC3200 ??
            when or if u install a C1 BOX > u have two cables> a CROSSOVER and a Ethernet Cable (look the same, but wired on ends different)
            Crossover goes from 3200 Printer port to C1 BOX> Ethernet connection goes from C1 BOX to your Network Connection
            are u a tech ?????????????????
            • ahmed96
              • Mar 2015
              • 11
              #21
              No I'm are not a tech
              I got canon clc 3200 and I am in Birmingham?
              • disam
                • Sep 2008
                • 64
                #22
                ok, you Need a c1, without this fiery does not work.
                • teckat
                  • 16083
                  #23
                  Birmingham England
                  best bet is to call a CANON AUTHORIZED DEALERSHIP and have a Canon trained tech look over your print options
                  • ahmed96
                    • Mar 2015
                    • 11
                    #24
                    i got the C1 as in the picture 4 i have only got the ethernet port. what will i need it to get connect this.
                    • disam
                      • Sep 2008
                      • 64
                      #25
                      you Need the I/F PCB, and nr 3 +4 without this you cannot connect the fiery.
                      FG6-9991-000 OPEN INTERFACE BOARD PCB ASS'Y
                      FH2-7042-000 CABLE, OPEN INTERFACE
                      FH9-0796-000 1 CABLE, CROSS
                      • teckat
                        • 16083
                        #26
                        [ATTACH=CONFIG]28494[/ATTACH][ATTACH=CONFIG]28495[/ATTACH][ATTACH=CONFIG]28496[/ATTACH][ATTACH=CONFIG]28497[/ATTACH]
                        CALL FOR SERVICE/
                        see similar C1 install pdf
                        imagePass C1 v2--Install.pdf
                        Color Network Printer Unit-C1.pdf
                        because u need the I/F board , I/F Communications Cable, Crossover Cable ,etc.
