need help Canon CLC 3200
  • ahmed96
    • Mar 2015
    • 11
    hi
    I have got a Canon CLC3200 the problem is that it only works on 32bit system not on the 64 bit machine. I have tried the drivers on the canon website when the drivers are installed then I send a print the printer say receiving and then the printer cancel the print.
  • disam
    • Sep 2008
    • 64
    Re: need help Canon CLC 3200
    Hi
    can you give more Information?
    which operating system
    which controller
    which port, chose lpd and the queue Name must be print
    • ahmed96
      • Mar 2015
      • 11
      Originally posted by disam
      Hi
      which controller
      using a windows 7 the port is the standerd tcp. The printer is connect to the router.
      thanks
      • copier tech
        • 8142
        What 64bit driver have you tried? Pcl5/6 or UFR?
        • ahmed96
          • Mar 2015
          • 11
          hi
          i have tried the pcl5/6 and the ufr drivers do not work on the 64 bit.
          • ahmed96
            • Mar 2015
            • 11
            I have noticed that in the service mode the ps/PCL are empty is there a software that I have to update on the printer?
            • vigour
              • Aug 2010
              • 1038
              I bet you have a Fiery box attached to the back of the machine.
              You need Imagepass C1 or C2 drivers for that
              • ahmed96
                • Mar 2015
                • 11
                No fiery box straight to the printer.
                • teckat
                  • 16083
                  Multi PDL Network Printer Unit-C1 (Optional) for CLC3200.
                  is this installed _?
                  There is support for 64bit_CLC3200\3220
                  Canon PCL5e/5c, PCL6 Printer Driver v14.00
                  This is for 32bit and 64bit Windows OS.
                  Compatibility:
                  Operating system(s):
                  Windows 2003, Windows 2008, Windows 7, Windows 8, Windows Vista, Windows XP
                  Language(s):
                  English
                  CLC3200-C1
                  Canon PCL5e/5c, PCL6 Printer Driver v14.00 (v14.00) This is for 32bit and 64bit Windows OS.tv tv
                  • disam
                    • Sep 2008
                    • 64
                    i'am not shure, but i think
                    CLC with a fiery box
                    iRC without a fiery box
                    try with lpd and Queue print.
                    • ahmed96
                      • Mar 2015
                      • 11
                      i have tried the lpd got no luck. the images i have uploaded in the service mode the ps/pcl there are no numbers
                      • ahmed96
                        • Mar 2015
                        • 11
                        Compatibility:
                        Language(s):
                        English
                        iR C3200
                        i have installed the drivers had no luck in thr printer log it says NG (#853)
                        • disam
                          • Sep 2008
                          • 64
                          Hi
                          Error #853 when printing --> The issue in this situation was that no printing options (PS / PCL / UFRII ) were detected
                          you Need a fiery.
                          • ahmed96
                            • Mar 2015
                            • 11
                            Hi
                            you Need a fiery.
                            Hi
                            how will I connect a fiery I have only got a enternet port on the printer?
                            thanks
                            • disam
                              • Sep 2008
                              • 64
                              hi
                              check here --> http://www.copytechnet.com/forums/ca...tml#post123995
