What is cheapest A4 paper brand you used for Canon IR105?
  • dedode
    • May 2014
    • 50
    Hi
    I think this question is the most important for all users for Canon IR105.
    What is the cheapest A4 paper brand you used for Canon IR105 WITHOUT too much JAMMING ?
    Regards.
  • copier tech
    • 8195
    Re: What is cheapest A4 paper brand you used for Canon IR105?
    What a stupid question!
    You get what you pay for, I have customers using the cheapest paper they can buy, & they wonder why they get so many jams, also cheap paper causes a lot of paper dust so blocks sensors, & lint sticks to the feed rollers etc so you'll end up replacing feed rollers more often.
    • tinnyjay
      • Oct 2009
      • 663
      Originally posted by dedode
      Hi
      Regards.
      DONT TRY THIS AT HOME!!!
      "Who loves the roses,must also bear thumbs"
      • nmfaxman
        • 1702
        Penny wise. Dollar Stupid.
        How much paper is wasted because of jamming?
        • tinnyjay
          • Oct 2009
          • 663
          Thats a small problem compared to time spent on servicing every 3 days plus stresssssss
          • dedode
            • May 2014
            • 50
            Ok, give us the best and cheapest A4 paper brand you use.
            Is this a good question for you?.
            Everyone tell us what the best for him, that's it.
            • tinnyjay
              • Oct 2009
              • 663
              I dont know where you live but check this here :
              PS. If you use this paper you must know that no problem in your copier is related to paper.
              • bigwul
                • Jun 2014
                • 60
                Those in the know bought cheap paper where I work - a whole pallet load of it - I got really really good at clearing jams and misfeeds!! - anyone want a basically unused pallet of 'cheap' paper?...free to a good home!!!
                • allan
                  RTFM!!
                  • 5462
                  The faster the machine the more obvious the paper quality becomes. One whole building used the same paper but my BH B1250 machines jammed into the drum pawls like clock work.
                  Turned out to be a bit of a bad cut edge. I change the paper brand and the problem was gone. The problem is to explain to them that the paper is NG and 30 other machines works fine.
                  So they would run out of good paper change back to the old paper, it took a fit from my side to get the operator to make his own life easier.
                  2 million prints later and no jams or jams i get called for.
                  Whatever
                  • dedode
                    • May 2014
                    • 50
                    Guys, we need others to get benefit from this discussion.
                    What is the cheapest brand you use without jamming?.
                    Tell us your experience , don't hide it.
                    regards.
                    • allan
                      RTFM!!
                      • 5462
                      You can feed anything thru a Ricoh 3025.
                      Maybe your machine is Jamming? The guys from this site is for a couple of continents so if i say Sappi paper is cheap and good its not going to mean anything to you.
                      your from nowhere its difficult to say.
                      Any ISO graded paper should be good.
                      Whatever
                      • dedode
                        • May 2014
                        • 50
                        Dear Allan.
                        I will order a container if this brand is perfect.
                        regards.
                        • allan
                          RTFM!!
                          • 5462
                          Where are you based?
                          Whatever
                          • dedode
                            • May 2014
                            • 50
                            Middle East.
                            • allan
                              RTFM!!
                              • 5462
                              I have even used good ISO grade % rice based paper. Made in China.
                              Cheaper to import than to manufacture locally. ZA stopped importing it.
                              Whatever
