canon irc3100
  • gladv
    • Apr 2015
    • 1
    [Error Code] canon irc3100
    hi, my copier show error code e020-0291, i change the m toner and clear the cluth , n dc con, can use few day ,after the problem is same . p/s help!!!
  • markndreu
    • Mar 2014
    • 34
    Re: canon irc3100
    hi, clean the developer unit of magenta or change it
    • copier tech
      • 8169
      Re: canon irc3100
      I just typed a long message but this shitty site crashed before I could post it!
      So basically it said keep the pach sensor clean, P-SENS above 500 & replace the drum BEFORE 90%
      This the secret to reliability on this series
      • Canuck
        Tech Specialist
        • 1713
        Re: canon irc3100
        Piece of garbage..just like 6800. 3100..yeh change drum unit and clean patch sensor.But no profit on a machine that eats drums...OPC drum...cheap...4 images on drum per copy....drums don't last shit. At least 6800 had an ASI drum that you got some life out of. Canon's worst product ever is the 3100..even 2050 ran better
        • ernesto
          • Oct 2011
          • 430
          Re: canon irc3100
          hi,
          COPIER > DISPLAY > DENS > P-SENS-P. this value is lower 500 clean patch sensor
          <REF-Y/M/C> should be betwen 464 to 560 if any color (y,c,m) it is nearly 700 or more you should make copies (10 or 20) in monocolor mode with the cover raised to low this value.....
          ATR sensor should be cleaned .....
          Be sure to generate the P-PRINT( COPIER>FUNCTION>MISC-P>P-PRINT.) when you replace OR CLEAR the DCCON to introduce the values appropiate again
          All the best
