Greetings. I attached two double-sided printing a IRC2380 on one side nitida out correctly but the other side is almost faded. Has been changed drums, power supply, HVT and side door. Do you know that you can be ?. thanks
Canon IRC2380
Re: Canon IRC2380
Interesting....
Make a force stop and check print quality on drums and so on.Determine where the problem begins.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
Re: Canon IRC2380
Is this the first side or 2nd side that is faded, as if you have damp paper the first side will be poor, then the 2nd side good as the paper has dried out going through the fuser.Let us eat, drink, and be merry, because tomorrow we may die!
​Comment
Re: Canon IRC2380
Greetings. Thank you all for answering.
First we have changed the whole door is where the Transferred roller.
Second problem is not fixed is intermittent so it is difficult to stop the machine also can not see the process in this machine.
Thirdly the paper is dry.Comment
Re: Canon IRC2380
I've seen the transfer belt cause faint printsLet us eat, drink, and be merry, because tomorrow we may die!
​Comment
Re: Canon IRC2380
Was the ITB UNIT the problem?
All the bestComment
Re: Canon IRC2380
Check the contacts on the process assembly(holds drums,itb). Clean them with sandpaper. When you close the right door there are also contacts at the end of the transfer roller assembly that make contact with the ones one the process unit. This contact on the door is known for breakingComment
Re: Canon IRC2380
Greetings. Thanks for answering. The door has changed in another machine and working properly. But the funny thing is that the breakdown cuandio print double-sided pages print correctly odd and even pages are clear. What bothers me more is that it is not a fixed symptom. thanksComment
