Ir3035 jamming in the fuser area.
  • tibbs
    • Aug 2008
    • 225
    This machine jams just before the fuser and also in the fuser when making Ltr copies. The pick-up / separation rollers are new.
    Can anyone help thanks much.
    Regards.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Ir3035 jamming in the fuser area.
    From senior tech i expect at least a jam code or some more info like printer counter or what you have done so far.
    -check for sticking sensor flag foam
    -old Fixing Film grease
    -worn reg sensor flag
    -new style Pressure Roller
    -fixing sensor flag
    -not have enough pressing between fixing rollers........
    • Dutchman
      • Jan 2011
      • 58
      Regards.
      Check the dail on the paper tray if that is set correctly with the paper used in that tray.
      • tibbs
        • Aug 2008
        • 225
        Thanks much for the response, I have replaced all the pick-up rollers / separation rollers. The paper tray dials are correct. It jams at Ps 10 for letter and at Ps 14 for Lgl.
        Thanks again.
        • tibbs
          • Aug 2008
          • 225
          The jamming codes are as follows: code 108 for legal size says a delay jam.Sensor Ps14.
          code 207 legal size stnry jam. Sensor Ps13.
          code 201 letter size stnry jam sensor Ps10.
          • copier tech
            • 8144
            Does it jam from both trays 1 & 2 & 3/4 if it has them? Also does it feed from the bypass tray?
            If it jams from all ports you can rule out pick up delay issues
