Canon irC2880 is 'grainy' when scanning?
  • Mr Davo
    • Dec 2011
    • 35
    Hi Everyone,
    At my work we have a Canon irC2880 MFP which we use for copying / faxing / scanning, etc.
    At the moment when scanning it produces a very grainy image, as can be seen below -
    If anybody can suggest what might be causing this, and further how to go about fixing it, can you please share?
    Kind Regards,
    Davo
  • ernesto
    • Oct 2011
    • 430
    Re: Canon irC2880 is 'grainy' when scanning?
    Originally posted by Mr Davo
    Hi Everyone,
    Kind Regards,
    Davo
    Hi,
    if the sample is a printed it could be the humidity content on paper ..... you can try to put new paper from the paper box
    All the best
    • copier tech
      • 8163
      If this is just scanning (not printing) try scanning to PDF not tiff & change the scan setting to colour & 600dpi.
      • Mr Davo
        • Dec 2011
        • 35
        The plot thickens...colour scans work a charm!
        Hello copier tech,
        The plot thickens here...whenever I scan something in colour it comes out crystal clear.
        I did note that the black & white scan defaulted to .tiff format, whereas the colour format defaulted to PDF.
        Is there some way of setting independent (e.g.: one for B & W, one for colour) scan settings (file format, resolution, etc).
        Any additional assistance will be greatly appreciated. I am yet to test with printing of B & W vs. Colour, but will report back once I do.
        Kind Regards,
        Davo
        • copier tech
          • 8163
          You will always get a better quality scan using PDF not TIFF, & always scan in colour, it doesn't cost anymore & as you can see the scan quality is better.
          You can change the default settings here, Additional functions<Communications settings<Transmit settings<Edit standard send settings
          This is from memory so might not be 100% accurate.
