HI I went to call and found pickup tires unhinged and actuator at turn guide off track .After repairing, Adf would feed ,but the original only comes 1/3 of the way out of doc feeder and goes into jam.I rotated the 4 sensors in feeder so that they were all in all the sensor positions. Same result each time I moved sensors to different positions,paper stops 1/3 the way out of feeder.If I run the duplex mode (2 originals to 1 sheet)the first original comes fully out of the feeder,but the second one never feeds in at all.I don't see many of these feeders,so any help would be welcome. Thanks Andy
Canon 1025 ADF NOT WORKING
Re: Canon 1025 ADF NOT WORKING
Hi Andy!
Probably is not assembled right.At the end you only regret why did you not take a photo.
Check some pics and docs if you can help with....
Capture1.jpgAttached FilesIf it ain't broke, don't fix it
A picture is worth a thousand words -
In this case is definetely ruled out.PCB can be a reason.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
