Canon 1025 ADF NOT WORKING
  • cucuklotz
    • Mar 2007
    • 611
    HI I went to call and found pickup tires unhinged and actuator at turn guide off track .After repairing, Adf would feed ,but the original only comes 1/3 of the way out of doc feeder and goes into jam.I rotated the 4 sensors in feeder so that they were all in all the sensor positions. Same result each time I moved sensors to different positions,paper stops 1/3 the way out of feeder.If I run the duplex mode (2 originals to 1 sheet)the first original comes fully out of the feeder,but the second one never feeds in at all.I don't see many of these feeders,so any help would be welcome. Thanks Andy
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon 1025 ADF NOT WORKING
    Hi Andy!
    Probably is not assembled right.At the end you only regret why did you not take a photo.
    Check some pics and docs if you can help with....
    • axyun
      • Aug 2007
      • 1323
      I gave Andy an open/close panel that was working from another 1025 and he swapped it and still had same problem. So pickup unit assembly is ruled out as the problem. Franl/ActionPhotocopy
      • zoraldinho
        • Mar 2008
        • 5018
        In this case is definetely ruled out.PCB can be a reason.
