imageRUNNER C1030if: NI-MH battery problem?
  • RandyW
    • Jan 2013
    • 213
    we looked at 1 of these machines today that was turning off & on. I think it kept trying to initialize.
    we disconnected a battery and it stopped doing that but not everything would work after that I think (2nd hand info, I have to check with our tech who looked at it to see what it did for sure)
    what the battery cause that initializing problem if it was too weak?
    thanks.
  • teckat
    • 16083
    Re: imageRUNNER C1030if: NI-MH battery problem?
    Connector J8124=Secondary battery for memory backup.
    Try Setting all WSD Print settings to "OFF"
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use WSD to "off"
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use WSD Browsing to "off"
    Additional Functions>System Settings>Network Settings>TCP/IP Settings>WSD Print settings>Use Multi Cast Discovery to "off"
    • RandyW
      • Jan 2013
      • 213
      Our guy went back over there and checked those settings. He said they were already set to off. I think he also accessed the service mode- can't say if he did anything or than that for sure...moved the machine to another spot in the office and plugged in to a different network jack. Started working. Maybe it was getting some strange electrical interference.
      • teckat
        • 16083
        Plug a laptop into that Jack & see if same symptom happens.
        • Canon345
          What voltage is on the line? What is the ground to neutral reading?
            • 23002
            Has anyone considered replacing the $5 battery? I'd be curious to see if it helped. =^..^=
