black ligne on paper with my IR3300????
  • REDAKAF
    • Sep 2014
    • 6
    it 3 day my IR3300 print - after 2 to 4 copy - a black line as it appear in picture
  • canonclc
    • 71
    Re: black ligne on paper with my IR3300????
    [ATTACH=CONFIG]29072[/ATTACH]
    looks like drum blade worn.
    • REDAKAF
      • Sep 2014
      • 6
      ok will try to clean it thnks
        • 23008
        Does it appear on internal prints, network prints, or scans? =^..^=
        • Iowatech
          Not a service manager
          • 3930
          I haven't worked on Canon equipment in quite a while, so this might be a useless waste of time.
          Still, if the line you are asking about is the line on the left side of the picture you shared, it kind of looks like there is some skew in the document scanning/handling area. It looks to me that the line gets wider the further down it goes on the picture you shared, and initially was there because that is the left side of the original casting a shadow on the platen/ADF glass.
          • hood4472
            • Aug 2013
            • 17
            Some things you can use to narrow it down is whether it happens only on internal prints such as reports or from computer then it's engine related, could be drum blade as suggested or dirty laser unit. Does it happen before it gets to the fuser or after that will eliminate the fuser.
            If it only happens on copies then check for only on ADF, then slit glass, or from platen and ADF, then dirty scanner mirrors/ccd.
            Good luck.
            Robin
            • REDAKAF
              • Sep 2014
              • 6
