Ir adv 8285 toner spilage
  • gksapple
    • Apr 2014
    • 116
    [CQ] Ir adv 8285 toner spilage
    HI
    ONE OF MY CUSTOMER(COPY CENTER) USING IR ADV 8285 ,WE ARE FACING TONER SPILAGE (DOT SPOT ON THE COPIES) WHICH IS APPEARED IN CENTER PORTION OF THE PAPER AND THE DOT IS NOT LOOKS LIKE A REPEAT IMAGE .
    1.THERE IS NO MARKS ON THE DRUM
    2.REPLACED THE DRUM AP KIT (EXCEPT DRUM AND PATCH SENSOR)
    3.REPLACED DEVELOPER UNIT
    4.CLEANED THE LASSER UNIT SHUTER GLASS
    5.CLEANED THE PORTIONS AROUND PROCESS UNIT THERE IS NO TONER STORED IN INTERNAL AREA
    BUT STILL DOT SPOT APPEARING ON COPIES (INITIALLY FEW LIGHTER DOTS WHICH WE CAN SEE IN THE ATTACHMENT AFTER MORE COPIES ITS VERY DARK AND APPEARS STRONGLY)
    TOTAL COUNTER :2300000
    NOTE :ALL PERIODIC Maintenance PARTS ARE REPLACED ACCORDING TO SM
  • vigour
    • Aug 2010
    • 1038
    Re: Ir adv 8285 toner spilage
    You need new primary corona wires
    Too bad you had to do all that work first
    Clean or replace the front filter also.
    • gksapple
      • Apr 2014
      • 116
      hi
      primary corna charger and secondary charger replaced recently (drb 1 counter is nearly 10%)
      front filter is also replaced
      • vigour
        • Aug 2010
        • 1038
        You did not mention ETB and ETB cleaner.
        I did fight with a spot/line issue which turned out to be a broken cleaner belt in the back.
        That cleaner belt tensioner has been modified too.
        I still think it looks like primary spots
        I beg you to replace the primary wires and prove me wrong
        I get that your primary assembly is 10%. Rated for 1 million
        The wire counter is under PRDC
        They are rated for 250000.
        6000/8000 are notorious for primary spots.
        The cleaners have been modified for that issue.
        They have even suggested using ImagePress cleaners
        Primary spots have been around since NP7550
        Were the spots there before corona assemblies were replaced.
        New parts occasionally fail prematurely
        Run 50 double-sided PG 1 or 4 , and you should see those spots get gradually worse. It may even change into a black band down the middle of the page
        • gksapple
          • Apr 2014
          • 116
          hi
          Tomorrow i am going to replace the primary charge corona assembly (modified parts fm3-7288-010) once i done let me update you
          • gksapple
            • Apr 2014
            • 116
            Originally posted by gksapple
            hi
            Replaced the primary charge corona ,dots spot disappered but one line is appearing on the front edge of the paper which is coming in feed direction of the paper
            note
            1. i supposed to inform when replaced the drum processing unit ,on time itself replaced the new ETB BELT,transfer roller,cleaning brush cleaning blade
            because DRB1 REACHES 100%(existing drb1 counter is 1%)
            2. back to the issue,after replaced pr corona ,replaced the secondary charge corona also but still line is appearing
            but the line is not appearing in list print its only appearing on copies to confirm the issue i took the auto gradation page its appearing on that page so as i observed if any toner consumption portion comes to the particular area this line visible .here i attached the copy.
            thanks for your previous suggestion and expecting your suggestion once again to close the issue
            • teckat
              • 16083
              note
              U mean lead edge ???
              Check the Pre-transfer guide plate on the Pre-transfer assembly for damage or displacement.=FL3-3802-000
              • julka123
                • Oct 2009
                • 36
                note
                Hi
                Check the shutter patch sensor .
                • gksapple
                  • Apr 2014
                  • 116
                  hi
                  actual problem was resolved after replacing the primary charge corona ,lines appeared because of auto image background density setting was adjusted by me(desity reduced) i forget set this into auto after replacement of primary corona.once i set this into auto it was ok .thanks for your support
