Canon imagepress C1+ HUNG UP
  • khattab.al.masry
    • 212
    [Dead] Canon imagepress C1+ HUNG UP
    Dears all:
    we face problems with our imagepress C1+ that when we power on the machine is loading and display that is warming up with no any change.
    we checked the temperature its not exceeds 34 c.
    we replaced the fixing assembly with another the result is the same
    the machine is hung up with warm up case and do not to be change.
    i attached the following pdf file showing the display massage and fixing temperature.
    with my greetings.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon imagepress C1+ HUNG UP
    If you have option try to swap AC driver PCB (UN35)from another machine.Any fixing error in the history?Did you try with clear dc?
    • teckat
      • 16083
      Originally posted by khattab.al.masry
      Dears all:
      with my greetings.
      check in service mode for any listed errors
      did u check your wall outlet for proper voltages & proper ground ???
      check/replace the fixing/feeding drawer connector===CABLE, DRAWER, 2
      figure 320 /FM2-2622-000/ item # 24
      • khattab.al.masry
        • 212
        We have checked the item #24 as listed by replacing the delivery assembly and fixing assembly with another machine.
        this machine which replaced with these assemblies was warming up
        • teckat
          • 16083
          Make sure Manual feeder door open/closed switch leads are not loose.
          Check continuity on J4002 pins 2 and 4 of the DC Power Relay PCB
          • Joseph2011
            • Aug 2011
            • 88
            muy cierto 100% que ese fue el problema lo he tenido en mas de 4 maquinas
            • khattab.al.masry
              • 212
              many many thanks mr.teckat the problem has solved according your advice we have checked this switch and found was cutting we have replaced the switch and machine was warming up.
              again many many thanks mr.teckat.
              Make sure manual feeder door open/closed switch leads are not loose.
              check continuity on j4002 pins 2 and 4 of the dc power relay pcb
              • teckat
                • 16083
                COLOR HAND.jpg welcome
