IR Advance C2020 Imaging unit replacement
  • copyman20
    • 207
    Greetings
    I need to replace a black IU for one of these copiers. Will the machine automatically setup the IU or do I have to run a setup in service mode?
    Don't have a manual for this model.
    • 8149
    Re: IR Advance C2020 Imaging unit replacement
    Yes you can simply fit the drum, the machine will reset the counter.
    You should also run auto gradation in user mode.
    • copyman20
      • 207
      Thanks for the help
