ghost image output at c3220
  • ps22sp
    • Aug 2014
    • 83
    see the picture magenta drum new recently replaced life 27
    transfer belt or drum downstream brush or upstream brush problem ?
    any suggestion ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: ghost image output at c3220
    Sorry but picture is like Disneyland.Do you have any service test print sample? Is PG-10 OK?
    • teckat
      • 16083
      any suggestion ?
      is DRUM & Toner OEM Canon ??
      did u do a AUTO GRADATION after replacement ?
      Check the external Secondary Transfer Roller Position ?
      1-What kind of Paper Stock ??? Normal , Glossy, or Heavy being used
      2-Check the four bias tabs on the Drum Unit Cover.
      The bias tab may be pushed in and stuck. If the tab is stuck in, it will create a poor contact to the bias tab on the drum unit resulting in background on the copies. There is one tab for each drum.
      Below is a picture with an arrow pointing to the bias tab.
      I darkened picture to highlight/outline image ghost repeat
      3- ??? are u running two sided copies ????
      • caini12345
        I would suggest to copy a good quality sample in 4 single colours to see if the issue is caused by a drum or something else.
