IMAGE PRESS C800( newly installed machine)
  • gksapple
    • Apr 2014
    • 116
    [Jamming] IMAGE PRESS C800( newly installed machine)
    continuous paper jam in a newly installed machine while taking duplex in 300gms paper exactly before ps24 (but location showing in machine ps35) location and its working with all plain paper upto 220 gsm.
    1 paper is feeding through additional deck
    2 proper media type and gsm setted
    3 same media is working properly with another machine (c800)
    4 single side is printed when paper is entering into reverse vetical lower section it got jamming
    5 its not reaching the the dulpex unit sensor ps24
    6 exactly under the flapper guide
    7 opened full reverse vertical path and checked there is no hurdles
    8 reconnected all the connectors near to the targeted sensor as per machine jamming history (ps35)
  • teckat
    • 16083
    Re: IMAGE PRESS C800( newly installed machine)
    Jam CODE_?
    Is this on long or short paper๐Ÿ‘€
    • gksapple
      • Apr 2014
      • 116
      Originally posted by teckat
      Jam CODE_?
      jam code 0213
      jam type stnry
      both long and short paper with 300 gsm
      • teckat
        • 16083
        jam code 0213
        jam type stnry
        Inspect connections below on Paper Pick-Up Driver PCB (check for proper voltages on pins )
        Issue only from Option > POD Deck Lite ( J1428 ) ?
        Reverse Delivery Unit ( J1406) (J1430) (J1405)
        • gksapple
          • Apr 2014
          • 116
          will check that and update you
          • UgaBuga
            Hi, all
            I have the same problem as you described. So please can you tell me how you solved it? In my case only media with 250x400 and everything till A3 can not go through the machine. It james before the duplex sensor. And the point is that only one sheet passed and second one always james.
            Thank you!
            Regards
            • teckat
              • 16083
              Originally posted by UgaBuga
              Hi, all
              Thank you!
              Regards
              Jam Codes ? IMPORTANT !!!
              Paper Pick-Up Driver PCB> inspect and check all connections
              is this from all Paper Pick-up locations ) Cassettes - Decks - other
              • UgaBuga
                Hi,
                well Jam code is 0116 - too late at duplex sensor1 PS24. It doesn't dipend from witch tray is paper. And if it is important the machine is with Prisma controller with the newest soft 4.1.
                I check ps24, ps34, ps35 they all worked. The only thing that I manage to find is that for example with A4 prints perfect duplex, with A3 the same . Only with the custom paper 250x400 duplex it james on the duplex flap. and it doesn't depend of the paper weight. I tried 80g, 100g, 200g and always first page pass through and second one james . I notice that duplex motor somehow didn't start for the second page. I also check the motor and it works fine. I can't find anything in the SM for this problem. Tomorrow I will check the PCB and the connections, but if there are problem with PCB how it works with A4, A3, SRA. with standard paper it works.
                Regards
                • teckat
                  • 16083
                  Hi,
                  Regards
                  Supported paper size-
                  -Pickup from deck=======A5R, STMTR, B5 to 13' x 19.2', Envelope
                  & Multi-drawer Paper Deck===============================
                  -POD Deck Lite======Envelope, Postcard, B5, A4, LTR to 13' x 19', A5R, STMTR
                  -Pickup from Cassette===A3, B4, A4/R, B5/R, A5R, LDR, LGL LTR/R, STMT/R, EXE, 8K, 16K 304.8 x 457.2 mm (12" x 18") 320 x 450mm (SRA3) 330.2 x 482.6 mm (13" x 19")
                  304.8 x 487.7 mm (12" x 19.2") Envelope, Postcard
                  Cassette 1/2/3======A3, A4, A4R, B4, B5, B5R, A5R, 11" x 17", LDR, LGL, LTR, LTRR, STMTR, EXE, K8, K16,K16-R 304.8 x 457.2 mm (12" x 18") 320 x 450 mm (SRA3) 330.2 x 482.6 mm (13" x 19")
                  Irregular size (100 x 148 mm to 330.2 x 487.7 mm)
                  -Pickup from Multi-purpose Tray====Cassette feedable size + long length paper size (service mode)
                  Size that can be loaded to cassette, Postcard, Reply Postcard, 4 On 1 Postcard, Envelope,
                  Irregular size (100 x 148 mm to 330.2 x 487.7 mm)(*3) Long original Paper (Length 487.8 to 762mm)(*5)
                  Paper size
                  Upper / Middle / Lower cassette===100.0 x 148.0 mm - 330.2 x 487.7 mm
                  Manual feed tray (option)
                  • UgaBuga
                    To update:: The problem was the software. With Prisma Sync controller there is a lot of problems with the soft. So we are waiting for new version to fix some of them. Thanks a lot .
