Advance C2022i network no responce
  • Harry
    • 228
    [Electrical] Advance C2022i network no responce
    Can not ping copier also when i get in Downloadmode to make system update get message storing update log the copier restart. Also try to ping copier itself no response. Any advice please from you guys thank you
    Harry
  • Harry
    • 228
    Re: Advance C2022i network no responce
    Figure out it is Main pcb 1 change this on another copier it makes the same issue is there a Way to reset nic on this PCB ? Usb Printing works good and everthing else work fine only Network print. Please help me
    thanks for advice
    Harry
      • 2621
      Print a user data list / network settings
      Then in service mode clear the mmi
      Service mode > function > clear > mmi
