Canon IRC 2880 Scanning issue
  • tech28
    • Jun 2013
    • 434
    Have new customer that would like to know if machine can scan 75-100 documents as 1 scan(know feeder is rated for 50). They scan batches to one location. Is there a way to with this machine? Multiple sets as one? Anyone run into this problem? Suggestions would really be appreciated. Thanks.
  • teckat
    • 16083
    Re: Canon IRC 2880 Scanning issue
    Why don't you just send directly from PC to location_?
    • Gazzahos
      • May 2014
      • 38
      On all Canon MFD's there is a feature called "Job Build". This will allow the user to load up the DF, run out and load more copies in the DF and add these to the job. This feature will also let you add scans from the Copyboard Glass to the file.
      The key presses to get to this area are.
      SEND (to use the feature)
      Colour /Gray (or whatever type of scan setting you have set as default). This is located on the RHS of the screen just under the scan settings display.
      Option
      Special Features then highlight Job Build to turn it on.
      • teckat
        • 16083
        Option
        Good Info, know about that.
        But don't trust Canon DF's. Especially on this series.
        • tech28
          • Jun 2013
          • 434
          Thank You for that information Gazzahos, as for sending from PC, they get docs that need to get printed, then they get scanned and sent to other agencies. We have been trying various ways top get around this, but to no avail. Now there is a way. Again, Thanks Gazzahos. Have a great day.
