C5045 removing finisher?
  • mrfuser
    • 1611
    Ok, need to remove finisher while ordering parts. When we do it says remove paper from output tray when client tries to copy. Any ideas how to bypass that?
    it is canon imagerunner advanced c5045
  • mrfuser
    • 1611
    Re: C5045 removing finisher?
    Ok got got that figured out and now it jams when printing. Looks like it tries to duplex and jams when pull back in. Walk up and copy duplex is fine.
    • teckat
      • 16083
      Print driver sees original configuration_?
      • mrfuser
        • 1611
        That's what I thought also so tried changing. Still no go
        • Gazzahos
          • May 2014
          • 38
          You also have to remove the bridge.
          When the sorter is first installed you have to remove a paper sensor arm for the exit. You will have to reinstall this arm.
          Always handy to keep the parts you remove when installing accessories. You never know when you will need them again!
          • mrfuser
            • 1611
            We are not original vendor so we don't have the parts. We did rove bridge unit
            QUOTE=Gazzahos;476590]You also have to remove the bridge.
            Always handy to keep the parts you remove when installing accessories. You never know when you will need them again![/QUOTE]
            • Gazzahos
              • May 2014
              • 38
              I think the exit sensor arm is the same shape as an iRC3380 style exit sensor. If you have spares of them try that.
              • mrfuser
                • 1611
                So that's why it jams on print and not copy? I don't follow
                [ATTACH=CONFIG]29506[/ATTACH]
                • Gazzahos
                  • May 2014
                  • 38
                  Good point...........
                  Do the copies and prints exit out of the same tray? There is an exit you can enable on the RHS of the MFP. Apart from that.......you got me!
                  • Canuck
                    Tech Specialist
                    • 1713
                    When it does face down delivery when printing it probably jams. Run 3 sets of 3 originals thru document feeder(copying)...probably try to deliver face down and jam. Yes you need to re-install the delivery arm assemblies.....
                    • mrfuser
                      • 1611
                      Ok, anyone know part numbers to order sensor flags?
                      • Gazzahos
                        • May 2014
                        • 38
                        ok, anyone know part numbers to order sensor flags?
                        fc8-4752-000 lever,2nd delivery full detect
