Bad Problems
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] Bad Problems
    Hello we have error code E805 in canon 2420 ...please help ?
    BEST TECHNICIAN . NICE PEOPLE .
  • Gazzahos
    • May 2014
    • 38
    Re: Bad Problems
    E805-0000 (Main body fan error)
    When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: Bad Problems
      [QUOTE=Gazzahos;476819]E805-0000 (Main body fan error)
      When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.[/
      well in your opinion where is the solution to solve this problems ?
        • 23010
        Re: Bad Problems
        [QUOTE=zaza;476821]
        Are you going to have Gazzahos go fix it for you also? =^..^=
        • Gazzahos
          • May 2014
          • 38
          Re: Bad Problems
          [QUOTE=blackcat4866;476822]
          For an MFD that old I would start at blowing out all dirt from the fan and possibly running it on a Power Supply at the office to test. Or take a fan out of your stock and try that for a quick "Blow n Go".
          Very rarely for a fan is it control signals or internal power supply. Being in Algeria I do not know the environment you are in or what area the MFD is in.
          Its a good chance to offer them a newer MFD though!
          Pay my flights and accomodation and I will fix it for you ANY TIME! (It can't cost that much from Melbourne, Australia to Algeria...could it?)
          • Jhonjon
            • Sep 2013
            • 208
            Re: Bad Problems
            This is a kind of thread that ask for a solution, but didn't do first what he have done to fix the problem. Give a possible cause still ask for the solution.
            • teckat
              • 16083
              Re: Bad Problems
              Check the fan connector. -
              J219 DC PCB
              Replace the fan. - Replace the DC controller PCB.
              What more do u need._?
              Basic Checks___DUH!!!!!
