ir 600 adf jam
  • jrivera
    • May 2025
    ir 600 adf jam
    I have a adf that is jamming at p1-13 senor,original delivery paper detection. i ran a sensor test and all indications show its working, i even replaced the sensor but still have the same jam code j-81. Any idea's will be helpful thanks.
  • BLITZKREAGG
    it sounds like your white belt drive is slipping or they are getting caught bup on the glass
    • eherrera1004
      • Sep 2008
      • 8
      about J81
      please, check the arm actuator of the exit paper, the side right there is a sensor with the actuator.
      • OtherTech
        • Aug 2007
        • 94
        Are the pickup rollers going up and down properly? The wiring attached to the front frame breaks inside the insulation(under the large black cover over the pickup rollers)
        • eherrera1004
          • Sep 2008
          • 8
          • yourownfree
            • Dec 2007
            • 474
            perform sensor init in service mode
